HSR and 85-89 L98
#16
Re: HSR and 85-89 L98
Originally Posted by 97WS6SCharged
I like that. Have you found a plenum or other solution for the HSR/Vette hood problem yet?
#17
Originally Posted by CamaroStylin
stealthram.com didnt say anything about changing the prom on the expense list. so i absolutely have to have a custom computer either programmed from an off the shelf or burned for my car. that just sucks really really bad. did all you guys do this?
#18
#19
i didn't put it on there as an expense because you can't pin down the exact cost. and not a have to just to swap intakes only. i did my own prom burning. cost me about $200. but if you can't do prom burning, you'll have to rely on someone else. and no you do not have to have a prom burned to get it to run. as i said in your post over at stealthram.com, when i did my 383, i ran the stock 1987 prom until i got it to a dyno. it's a little harder to start in the morning because of no 9th injector on the HSR and using the 87 bin that still had the 9th injector programming. i drove on the stock 1987 bin for a month. and when i did finally dyno tune it, i only had to add 5% more fuel to the entire curve. then added fuel in the 4000-up after that.
#20
what about the MAF? does the holley system use a MAF or a SD sensor? if it takes one, how would the other be able to be used on the system?
I'm lookin the car over on saturday that ill be installing this in btw, so this install isnt far away. thats why im asking all these questions
#22
