HSR camshaft recommendations ??
#16
Formularpm: Would you say to go with 110* or 112* lobe separation on these cams? Or do you think this makes much difference overall?? I guess the 112* cam will idle a bit better.
#17
Actually the comp cams catalogue shows the XR276HR with a 112* lobe separation (# 08-503-8) under the 'Extreme' series of cams designed to work with computer controlled vehicles from 1987-1997 (except LT1-LT4).
This cam might just be the ticket for me.
Looking at the catalogue I noticed the 280HR Magnum cam (# 08-430-8)with 224* duration lobe has more lift (.525") than the 'Extreme' cam with 224* lobe duration (.502").
It seems that the magnum uses a more agressive lobe? But it's a narrower RPM range advertised.... Camshaft science!
#18
you can also post this over at www.stealthram.com i'll be using a crane cams 119831. according to DD2003 pulls more above 4500 than the comp cams 305
hp compare
tq compare
will find out in about 2 weeks.
hp compare
tq compare
#19
#21
Originally posted by stealthramman
Check page 144 on the pdf catalogue. It looks like the 276 is the biggest they recommend for computer controlled cams.
#22
aklim is exactly right. In fact, with the corrrect programming, you can actually streetably run more cam duration with EFI than a carb setup. This is due to better fuel distribution to the cylinders and increased control over air/fuel parameters at different engine states. (idle, cruise, WOT, etc)
#23
Well i'm looking to produce about 400 hp with a nice broad torque curve. I'm thinking that a 270-276 adv. duration hydraulic roller with some nice (over .500) lift will get me there with a hp. peak around 6000rpm.
Probably not much need to go bigger than that.
Agree or disagree??
Agree or disagree??
#24
Re: HSR camshaft recommendations ??
I have an HSR as well and want to run the XR282HR on a 112 LSA. Formularpm, how is your vacuum at idle? I know this is old as dirt, but hopefully you guys are still around.
