I think I found the problem - the computer
#16
Originally posted by Pro
Do I need to go through replacing these spark plugs again?
They have about 200 miles (3 months) on them, but I pulled cylinder 1's spark plug out (like I mentioned above) and it sure was pretty bad. It should burn off shouldnt it (assuming the motor isn't running rich any longer, which it doesnt seem to).
Also what is the normal idle speed for the motor? It runs at about 1200-1300rpm during warmup, and idles at 0mph in drive at about 700.
That sounds about right. You do want to get a scanner to see what the ECM is reading anyway if you want to adjust the idle and TPS. Your tach could be wrong. I know my ECM data matches the snap on gauge I hooked onto the wire but may differ from the stock tach.
HuJass
18
06-24-2002 09:19 PM
