Idle Screw...
Idle Screw...
What happens if you mess without idle screw on the throttle body without disconnecting or doing it the proper way? Cuz i was messin with it a while back and i noticed that after that my car started trippin, holla.
The only way to check if the sensor is bad is to put a voltmeter on it. Go get yourself a haynes automotive manual...that has the correct procedure...
i would get mine but its all the way in my garage and its raining like hell
I get everything except where i am supposed to put the paper clip...
...Take the paper clip and open it up and form it into a big "U" shape. Insert the clip ends into the ALDL in the 'A' and 'B' pins.
what is the ALDL
what is the ALDL
autoxr166
09-25-2015 04:21 PM
