Ignition Problem
Ignition Problem
Well there is a new thing on the problem list for my 84 Z. There is something wrong with my ignition. It will not turn over. It goes into the auxilary position but it will not go into start. It also will allow you to go through all the gears with the keys out. It started like this: First the battery went dead, i thought this because you turn the key and nothing would happen. Then when I got a battery charger and tried it again the ignition would not even go into the start position but you can shift through all the gears. Any help is appreciated. Thanks.
Oncomingstorm22
01-22-2015 07:15 PM
