Installing air/fuel gauge
I installed an air/fuel gauge that I got from 818camaro95 into my car, and all it was doing was reading Rich. So I put a multimeter on signal wire and it's reading over 2 volts. The sensor I'm using is a Bosch heated 02 sesnor for a zr1 corvette. I know the range should be between .050 and 1.00 volts for the gauge to read. Basically what I'm asking is do you think it's a bad o2 sensor? It's a carb car so it's not hooked up to a pcm to trigger a ses light.
-Jim
-Jim
Re: Installing air/fuel gauge
Since it's a carbed car, try leaning out the idle mixture to see what happens before you spend the money on a new O2 sensor. If you can get it to read correctly at idle, then you can move on to getting the cruise and power enrichment worked out.
Location: China now, Originally from Iowa, then worked in California
Those AFR gauges that use a narrowband O2 sensor are about as accurate as a weather vane is at telling you wind speed (i.e. they just point in the direction of the wind).
Originally Posted by 1987IROC350
But they look good at night in a pillar pod
Yeah, those things are strictly for show, you can't gain any remotely useful information from them other than being to tell if the 02's are working or not.
Originally Posted by thirdgenrallysport
new ones out are supposed to be accurate to within 0.1
Edit: In response to the quoted post above, it could be compared to an oil pressure gauge. The gauge itself could be accurate to within ¼#, but if the sending unit is accurate to +-10#, you wouldn't know if the readout was registering accurate #s.
99TransAmWS6
02-12-2015 07:23 PM
