installing the corner wings on iroc-z
my third wing is cracked the little corner one!!! so i got a set from ebay there not here yet but i was just wondering how im supposed to get the old one off and the new one on.
any help would be appreciated
Its pretty easy bro. For the center section you need to take off the plastic thing that covers the decklid. Once you take that off you will have access to the nuts. I think they are 10 mm.
For the right side you need to take off the the center panel and the panel that covers the spare tire. You also need to take off your tailights to make access to the speed nuts easier. 3 speed nuts hold each of those pieces on. The top one is a pain in the a** For the left side just do the same. You can take the whole panel out but I just loosened the bolt that connects the strut to the body then bent the panel out while i loosend the screws.
There ya go man!
There ya go man!
