Iroc-z ??
Won't the RPO codes tell you? Run 'em at www.thirdgen.org
You know what I'm talking about right? That little compartment you need a key to get into? I forget what years it was but it also might be under the console lid. For an RS, all I can find that MIGHT be it is R1V: Appearance Package
I've got F41 (mine is an RS) and that's
F41 : SUSPENSION SYSTEM, FRT, RR, FIRM RIDE, HANDLING
I'm nut sure if F41 is just on RS's though.
If you cant find the RPO codes under the hatch area Try looking in your center Consol area. should either be on the lid or just in side on one of the sides. Make sure the Vin matches the vin in your car.
