little help with motor mount
#16
Re: little help with motor mount
well i put them in today and ended up slippin the bolt up from the inside and putting the nut on the top...worked out pretty good....that is a poor GM deisgn there I tell ya...rediculous, there better not be a clearance issue otheriwse i'll be pissed...
#18
will do...ran into a problem with my distributor tho...it won't fit with the new HSR manifold!! i'm pissed..anybody know if i can put the engine in then put the distributor in later?
#19
People remove and install distributors all the time without having to take the motor out. I don't see why not. But it might be a pain in the *** once the HSR is bolted on. Looks like it sticks up and goes right up against it
Will
Will
#20
well i'm putting in the dist. with the upper plenum off the intake...a talked to a few people and they say it will be no problem..i hope they are right cuz i just got done putting the motor in....and also, as far as my bolt head in the k member and nut on top idea for the motor mounts, it worked! no interferance at all, worked great, and it allowed us to just use a box end wrench on the inside of the kmember and we used a rachet and socket on the outside....still cramped quarters tho...
