Loose door handles
#16
Guest
Posts: n/a
Hey, I tried to get a pic of the upper part of the door. Do these bolts look right?
ftp://68.1.231.79/camaro/door.jpg
I thought they were kind of small for what they should be, but they came off pretty easy.
BTW I took the handle off, and moved it down a little bit into the grooves, and it tightened the rod up a little. Now there is just a little play between the base and the actual moving handle.
#17
Yep, those are the stock nuts. Just tighten them up real good with a pair of long needle nose. They should fit in there real nice. Also, as mentioned in my earlier post, if I recall correctly, even though you tighten them up, they will still appear to be a little wobbly because the handle itself doesn't not seem to fit real tight on the base.
cmsmith
08-09-2015 07:30 PM
CARiD
07-07-2015 08:19 AM
