LS1 transplant
LS1 transplant
While picking up a door from a local salvage yard i ran across a COMPLETE LS1 motor for only 3K. It includes the six speed tranny brain box wiring harnesses everything. My question is how hard would it be to put that motor into my 1990 that has an automatic. any and all input would be very much appreciated. thanks
1990 camaro rs
never raced it because, well its slow.
1990 camaro rs
this has been beat to death much like 4th gen seats...........do a search and you'll find your answers easier.
it isn't that it's hard to fit, infact it's easy to fit; it's the custom motor mounts as well as a few other trick signature parts that will need to come together......as well as trying to match everything up and get it to run right.
many have tried, few have got it to work well....very rarely do you see one that runs perfect although it can be done. i'd say at least set aside another 3,000 if not more for added expenses as well as alot of time and your good to go. don't be surprised once you fit it in the compartment on how small it looks......almost like a 4 cylinder, but if you pull it off it should be nice.
good luck!!
good luck!!
Here is someplace to start:
http://www.fbody.com/members/LS1IROCZ1/index.htm
1990 Camaro RS
1991 Acura Integra LS
http://www.geocities.com/joecool_2u/
LT1 swap in progress.
XE 230/236 cam, 1.6 roller rockers, "R" lifters, Underdrive Pulley, air foil, and SLP headers.
Posi 3.73 9 bolt rear end, BMR suspention components, 3200 Vigilante, and Transgo.
1990 Camaro RS
<font face="Verdana, Arial" size="2">Originally posted by rickyzZ28:
</font>
</font>
1984 Camaro Coupe LG4 V8 (5.0L 305ci)
- 700R4 Transmission
- K&N Filtercharger
