LT-1 in a 86 I-Roc
y woudl u want to put an LT1 into a 3rd gen.. i mean an lt1 is a l98 on crack.. reverse cooling.. opti.. not alot of aftermarket mods for it.. IMO just get an L98 and put a mini ram on it if u want the LT1 look
Not a lot of aftermarket mods for it? Are you serious?!
Eric
Can I get an LT1 into my 91 TBI? Does the TBI also use reverse cooling? Or am I better off getting the LS1. LT1's are much cheaper to modify than LS1's. Just take a look at the price of LS1 cams..$500.
Originally posted by 1fastformula
VORTEC heads rule!!!!!
They're good stock, but there are far better heads out there to use in a built engine, IMO.
Eric
Originally posted by LT1Powered85Z
Vortec heads are good STOCK heads...but they don't offer much to work with along the lines of porting. Not only that but they're cast iron. Who wants to run iron heads on a performance application? Sure as hell not me.
Eric
Eric
The reason why you cannot port them is 'cause GM said "Why sell a head that needs to be ported....lets do it for them". Ok, maybe then did not say that, but that IS the basic principle. All I need to do is do some spring work and change the cam and I will have a bonified 385 HP mill with IRON heads. Heavy Bastages
I thought you had a website for your car......I think I have seen it but would love to see your LT1 application again!!
Later
Don't be jealous because your running an LT1 j/k
Later
Later
I do have a website for my car...but it is outdated...I need to get some more recent pics, etc. BUT...there is a link in my sig to the website.
Eric
irocbob89 has an lt1 in his 89 iroc. pics here:
http://photos.yahoo.com/bc/camaroguy...tos.yahoo.com/
