lt1 runs, now have a header question
well it took about 2 months but the lt1 now runs, starts right up and sounds great. I havent been able to drive it yet though because all of the suspension is down im putting eibach prings in with kyb struts, shocks sub frames, control arms, panhard rod with all new bushings. Im so excided. When i go to put headers on the car though i want to get hooker super comps. I know im soppose to buy the thrid gen headers but what do i do about the o2 wire? the 3 gens and 4 gens have different connectors so how would i go about getting the lt1 extenders? thanks
Bobby
89' red iroc-z
386 stroker
Mini ram, 58mm tb
30#lbs,255 high flow fuel pump
slp cam, 1.6rr
edelbrock performer heads p+p 2.02 1.60
Hooker super comps, Mufflex 4' exhaust
Ford 9' 4.11 gears, detroit locker, 31 spline
Full suspension
B&M mega shifter,2800 stall
baer rear brakes,line lock
converted to speed density
Ed Wright dyno tuned
89'red Iroc-z 5.7 TPI
t-tops grey interior
free mods, exhaust
Lt-1 convertion in the works
Bobby
89' red iroc-z
386 stroker
Mini ram, 58mm tb
slp cam, 1.6rr
Full suspension
free mods, exhaust
Did you use the stock wiring harness or have one made? I bought a harness from injection technology and it had more than enough o2 sensor wire to go to hooker.
92 firebird
93 LT1, Hooker shorties, Borla back, Homemade CAI, Airfoil, 2400 TC, SFC, all free mods no cats. Nx 100 shot very soon.
92 firebird
The lt1 has a 4 prong plug i think that goes into the o2 sensor, i just spent alot of money on this harness and i really dont want to splice it all up. I was just seeing if anyone knows if i can get the 02 extenders with the 3rd gen hooker long tubes? thanks
But if worst comes to worst i will splice the o2 wire
irocbob did it take you 2 months cause you took your time on it? And i am from chitown(burbank) too and i am gonna throw an LT1 in my 92 rs so i'll have a lot of ?'s, one simple question for now is, did you use the trans that was in your ride? and did you run into alot of problems?
oldschool
02-09-2016 09:21 PM
07-04-2005 05:00 PM
