LT1 swap question, wiring harness
Old 08-23-2003, 06:05 PM
IgorT.455/406's Avatar
Hey guys. My '94 car the x-gf wrote off not long ago, and I am thinking about swapping the LT1 into it. I was wondering, I heard Painless makes a harness that will just bolt into the thrid gen and work with the LT1. Is this true? Where does it bolt into the car, same place as the other harness? How much is it?
What about the fuel pump and fuel lines??? That is what has me confused, will I have to run ALL new lines or what? Thanks guys.
IgorT.455/406 is offline
Old 08-23-2003, 08:46 PM
LT1Powered85Z's Avatar
Personally I don't think Painless makes a quality product. From what I've heard from a LARGE number of people who have e-mailed me for help, they aren't very good.
I used a Howell harness and it's an excellent product. Everything is tagged and the connectors that are used are identical to factory and everything is mesh covered. It's a VERY nice harness.
TPIS sells them, and that's where I got mine. They can add or remove anything in the harness that you don't need/want if you'd like. Just specifiy what you want/need when ordering so they can have it properly made. If you call (952.448.6021) ask for Jim Hall. He's a real good friend of mine and he can get you set-up well.
Eric
LT1Powered85Z is offline
Old 08-24-2003, 03:32 AM
redimpss5's Avatar
cant help you with the harness part! i put in a harness from the car i got donated from, and since it is more of a race car, a few things that you might want on a street car i did not worry about! i have an 85 and it has two fuel lines from factory. i was worried about it to at first, but no problem!! a lt-1 needs a to and from line. use the factory line from the tank and add a electic fuel pump to it. use the other (i think it was a vent line) for return. i have no problems doing it this way! for safety, make sure you install an inertia switch. goodluck
redimpss5 is offline
Old 08-24-2003, 06:31 PM
What is the inertia switch, and what did you cut out of your stock harness? My car is a street car, but I won't want a lot of the stuff. I also don't want to spend too much money on it, as I want to build another motor for it. Thanks a lot.
Thanks for the info on the other wiring harnesses, how much money, anyone know? Thanks.
Old 08-24-2003, 07:41 PM
redimpss5's Avatar
inertia switch will shut off fuel if you get into a wreck, so fuel dont leak all over the place. i think its more for fire. i just cut the wires at the firewall and ran all the new wires from the pcm into the car thru the old a/c hole. some need to go in the car.
Old 08-24-2003, 10:16 PM
94z'sson's Avatar
lt185z
i finally broke down and bought a Howell harness and it is the best money i have spent
the car isnt ready yet but howell was a great help and the harness goes on perfect
i had to pull the injectors off and get new ones so i went ahead and got the hotcam and i am in the middle of putting that in
94z'sson is offline
Old 08-25-2003, 10:37 AM
Thumbs up
Originally posted by 94z'sson
lt185z
Congrats! Someone finally saw the light. Everyone is concerend about price over quality, so they get Painless stuff. You get what you pay for in this instance, for sure!!
Howell is very good. Who did you buy it through?
Eric
Old 08-25-2003, 11:37 AM
Eric
So how much is it?
Old 08-25-2003, 01:03 PM
aklim's Avatar
I have seen painless wiring and I am not convinced of the quality of the product. It might be OK if you are fixing up a car with a bad harness and you are selling it.
aklim is offline
Old 08-25-2003, 01:44 PM
BrianI's Avatar
I've been looking at the Speartech harness. How is it compared to the Howell?
BrianI is offline
Old 08-25-2003, 01:57 PM
BrianI's Avatar
Igor, I think the Howell is $595.
BrianI is offline
Old 08-25-2003, 02:06 PM
That is nutz! Makes life easier I would imagine, but still.
Old 08-25-2003, 02:22 PM
I got my Howell harness through TPIS like 3+ years ago, and it was cheaper, but that was a long time ago. Now TPIS gets $595 for their's.
It's worth it though. Not only do you have less hassles/headache but it's also a superior product. In addition to that, they will build it to order, basically. If you don't want A/C or if you don't want something else, they will build it without it, so it's just plug and play. Nothing to cut out or remove. It just snaps into place...
Very worth it, if you don't have in interest in spending tons of hours tracing wires all over hell.
Eric
Old 08-25-2003, 02:48 PM
BrianI's Avatar
Do you send them your harness to modify or do they supply it to? The speartech is $450 and you have to send them your harness.
BrianI is offline
Old 08-26-2003, 12:12 AM
You buy an all new one from them, so you'll still have your factory harness if you were to need it for something. Just another reason the TPIS/Howell one is superior.
Eric
Quick Reply: LT1 swap question, wiring harness
