LT1 swap question, wiring harness
Old 08-26-2003, 03:32 AM
  #16
BrianI's Avatar
Do you have to put the computer in the stock location with the Howell or are the wires long enough to put somewhere else?
BrianI is offline
Old 08-26-2003, 08:17 AM
  #17
Zepher's Avatar
We had the Speartech harness and installed it on my friends 82 T/A. Speartech was great to work with. They built the harness with what we needed and also made the wiring long enough to where we wanted to mount the PCM. They asked us where we planned to mount the PCM, gave then an estimated length and they made it.
Zepher is offline
Old 08-26-2003, 08:19 AM
  #18
Zepher's Avatar
Originally posted by BrianI
Do you send them your harness to modify or do they supply it to? The speartech is $450 and you have to send them your harness.
You can buy a complete harness from them for $600 or $700 depending on if you run MAP or MAF.
Zepher is offline
Old 08-26-2003, 08:50 AM
  #19
LT1Powered85Z's Avatar
My ECM is in the stock 3rd Gen location. They made the harness long enough to do that, because I asked.
People complain about $595 for a great Howell harness, yet Speartech goes between $600-$700? That is way expensive, and I doubt it's better than a Howell piece.
Eric
LT1Powered85Z is offline
cmdeshon
01-04-2015 11:15 AM
siguy
11-27-2014 10:07 AM
07-04-2005 05:00 PM
$hawn
08-03-2002 04:59 AM
CobraEatr
07-23-2002 06:32 PM
Quick Reply: LT1 swap question, wiring harness
