maf burnoff relay
maf burnoff relay
can someone show me a picture with the location of the maf burnoff relay on it or a more detailed location for it.. i was told it was on the driverside firewall and that it uses the same relay as the fuel pump. i replaced both relays there and i still havfe the code.
Re: maf burnoff relay
Replace the relay, and blow out the maf. Carefully.
If that does not work, swap in a known good maf. Autozone can test the maf's.....I think. I know they can test ignition modules....
If it comes back, or you still are haveing a problem try these: http://web.camaross.com/forums/searc...archid=1087297 They may help.
Aaront810
08-29-2020 09:34 PM
Ryan Ramsaran
09-19-2015 08:43 PM
