Mass Air Sensor Upgrade
#16
Originally posted by IROC-T
The unit you linked to was $398,you should be able to pick-up MAF at pep o' boys for around $150. So I would say you saved $250 ,no? Like I said I did my stock MAF like they do (or similar),and it was flow tested at around 750+ cfm. Ok there are some people that can't follow directions , and people that can't work well with thier hands , this is a delicated item I was afraid to do it also ,but like I said I went slow and steady and followed the directions given me and it turned out ok. As for flow rate unless your all ported out and are running a 58mm TB and maybe some pressure (blower) 750cfm should be more than adequate.
oldschool
02-09-2016 09:21 PM
95chwagon
01-13-2015 09:19 PM
