need advice
Originally posted by Marc 85Z28
For your stock 16x8 wheel, go with a 255/50r16 tire for a slightly wider tire. The 255/60 will most likely rub, and will throw your speedometer by a good bit.
Purley for looks man. My jeep has bigger tires in the rearand it looks cool. I made up for the difference in size by running different gear ratios in the axles. Wouldn't a 265/60 16 be a little wider and taller?
WobblySausage
10-07-2015 10:09 AM
