Need help with my 89' iroc 350 tpi
i need some help with my 89' iroc 350 tpi. the problem is i turn the key and get nothing. i've put a new battery,starter and all the cables for that. Before i put a new head unit in and it hasn't started now. but before that it was running but it was starting. so i really don't what is going on so plese help.
Re: Need help with my 89' iroc 350 tpi
are you getting signal power to the starter solenoid?
jump power the the starter solenoid form the big post(a screw driver works well for this)
if it turns over good, you got a control issue,
VATS wire breaking at the ignition swich is a common cause to this problem
gonzo275rltw
09-05-2015 06:26 PM
