need manual tranny options that can handle a 383
Re: need manual tranny options that can handle a 383
T5 isn't rated for that kind of torque, so it will wear out the tranny quicker then it normally would,
but you don't usually break stuff unless you are getting traction,
but even a T56 will break with traction
either jegs or summit have a t5 listed that is upgraded to handle alot more power. one is 500#s and the other is 600#s of torque. they are listed for the mustang, but there's got to be some built for the fbody (or maybe they are interchangable...not sure)
Originally Posted by 89Vert
Again, not picking on your choice at all, just pointing out that for $1700-2000 you could have a pretty sturdy T-56 with cash left over.
Originally Posted by Rottluver
Not bashing but for those prices, a built T-56 would be as good if not better an option IMHO. I am a huge fan of that 6th gear for cruising.........
thats why I want Tremec instead of Richmond,
T56 is not a great tranny, not a bad tranny but I know lots of guys that have blown them up, even built,
I got a 95 Z28 with a blower and it took out a stock 6 speed without problems
I beleive they can only handle in the neighbourhood of 450ft.pds built
I was looking at the 600ft.pd Tremec with a .64 OD which is more then enough,
but who knows, when I got the cash in my hand if a T56 pops up, I might go that route
my motor will be around 450-500hp N/A and 500pd.ft with out the nitrous
probably going to back it with a Ford 9", don't think my 9 bolt with last very long
I like the idea of overdrive too,
Guess I am lucky, there is a local guy here who does wonders with T-56's. Well beyond 450 ft/lbs.
