New Interior for my 82'
hey i'm looking to change the seats and carpet in my 82' Z28 the only thing is i want to be somewhat original so i wanted to try to use the interior out of maybe a 94' or newer camaro but i don't know if that's possable so if anyone has done something like this could you let me know. thanks a lot.
Very easy to install 4Th gen seats.
Remove protective caps from front seat rails
and you are set to go. Now remove a total of
(12) 14mm nuts from the front and rears and presto the interior is out. now is the time to replace or clean your carpet. The install
is the same as before using the same 14mm nuts. No mess or fuss just a direct bolt in
for 4th Gen Seats. Check on www.thirdgen.org
for more detailed instructions. Good Luck, did this last month to my 87 IROC.
Henson071
12-30-2015 09:55 PM
