new manual transmission
#16
Whoa, no way. To have the WHOLE job done, it was quoted at 350-600?? Now that'd be some great news! Was that just some local automotive place that gave you that estimate? Cuz at this automotive place here in St. Louis, to have a Richmond 6 speed installed in my car, the labor would be 2 or 3 THOUSAND! Not to mention the 3 grand in parts needed, including the transmission. So that would be a 5 or 6 grand job right there... does that sound right or was the guy at the automotive place full of it? Why would it be cheaper to have this particular transmission installed in my 92 Camaro? Just curious cuz neither transmission was created for my car particularly... so does the one that you pointed out on the performance unlimited web site just fit better naturally?? If I go to this local automotive place with a printed copy of the web site and ask how much they think labor would be, should I expect a similar estimate? I certainly hope so, cuz that would just answer all of my problems right there. I could have that done now and have money to spare!!
-Matt
-Matt
#17
Another quick question... the "GM Tremec T-56 93-97 F-Car" transmission that you showed me on the performance unlimited site, is it the same as the one at this link:
http://www.sallee-chevrolet.com/BorgWarner/bwt56.html
really really curious because there is a 400 dollar difference in price!! It sounds like its exactly the same thing though. So does that mean that the "GM Tremec T-56 93-97 F-Car" tranny is considered a "retrofit" also? On skulte's page they make it sound like it slides right in!!
-Matt
-Matt
#18
If you have to pay a mechanic to do this swap for you, forget about it and go buy a thirdgen with a stock 5-speed. Between buying the 5 speed and paying for the install, you're looking at $2500 or more. Combine that with the money you can get from your car and you'll have yourself a damn nice TPI 5-speed car.
#21
Tekno....if it's a T-56 you're throwing in you can get a flywheel from Centerforce for a little under $300. That's where I got mine. It's the only place I could find that had a T-56 flywheel for an early-model block.
As for swapping costs: I am a professional mechanic and I can tell you from personal experience that swapping a T-56 into a thirdgen is cake. With the appropriate conversion parts (crossmember mainly) it's practically a direct bolt-in. I did mine on a gravel driveway with the car on jackstands in about 9 hours total labor. With a lift and air tools, it would be much less. If you were to bring your car into my shop, with all the necessary parts, it would probably cost you right around $450 for us to swap it in. If you get the tranny and most of the other parts from a junkyard, you can probably have it in the car for $3000 or so. I did mine for less that 2 grand, but as I said I did my own labor.
#22
http://128bitencrypted.com/centerfor...tarq=CHEVROLET
Part # 700100 and # 700177 match
will those work?
Chris
will those work?
Chris
#24
Originally posted by guitarman
Really? You think it would only be about 2500 for parts AND labor? If thats the case I'm all for it the swap. Theres no way I'm selling my Camaro though.
#26
will those work?
Chris
will those work?
Chris
#27
Well i had a T5 that stood up to a 305 TPI for 135,000 miles.Then i swapped in an L98 with lots of mods.It stood up to it for about 10,000 miles.Blew that motor running an LS1 on topend.Swapped in a 409 small block with superram,cam and many,many more mods.The T5 hung in there for a few thousand miles of that motor before it finally needed rebuilt.Maybe i was the exception but i think the T5 gets a bad rap.
#30
That T-5 must've been a factory freak. They're out there, but there's no real way to find them......every once in a while you'll just see one that'll hold up to all kinds of power, while all the other supposedly identical tranny's are blowing like Old Faithful.
F'n1996Z28SS
08-23-2023 11:19 PM
