not sure i understand "flash" codes
i was reading the proceedure on 3rdgen.org and i dont understand how they get "12" out of the flash sequence they gave for when you do the paperclip trick. Also, will it throw codes even if the check engine light went off? And....what if there is multiple codes, how will i be ablte to distinguish between the different codes? Thanks.
Try it and you'll understand. If you see one flash, then a pause, then 2 flashes, that's a code 12. If it flashes 3 times, pauses, and flashes 4 times, that's a code 34. There will be a longer "double pause" between codes. Each code is repeated 3 times.
thanks to all that replied, its a big help. now where exactly can i find the fuse box that i gotta get to to do this? i have an 84 z28 305 HO. I have to connect the 6 and the 12 slots(how it shows it on 3rdgen.org), right? Thanks again.
CARiD
06-18-2015 08:56 AM
[Problem] F-Bodyworld.com/Jon Massaro WARNING!!
DarkKnight
Buyer/Seller Feedback
05-11-2015 10:03 PM
