Open Dif.
#16
over on TGO Dan Burk has a tech article on "how to build a better 10 bolt" me im a 9 bolt (not 9 inch) guy and i love em but its not finding the parts, its the cost of the parts. im currently looking for an empty 10 bolt housing to build for my 89 formula so i can rebuild my 9 bolt and leave it put up.
#17
By the way "quickchicken" I noticed you live purdy close to my Dads side of the family. I have relatives in Olive Branch, South Haven, and few other towns in that area. I usually make a trip down there once a year.
#18
im in Byhalia, actually just up from the town of Byhalia on 309 just 2-3 miles south of 302-goodman. i can hit OB or Collierville in 15 mins.
#20
Just an update as to were I'm at right now, I pretty much need to just install the Powertrax, then the axles. Oh I found out through the guy who's been given me pointers at the rear end shop don't use Raytech crush sleeves, because they weld them. He showed me a couple of samples of what happens, they split at the weld. And if I didn't say so all ready, don't use the new smaller head bolts for the carrier. As he showed me what happened to a couple of rear ends he had to fix because the bolts separated from the ring gear/carrier and destroyed the internals.
#21
i have heard the folks that have used the power trax said its NOIZY! clicks like a merf going aropund turns and another fella said the rear shifts a bit till the teeth lock. i wanna hear first hand on how your acts after you have driven it.
#22
#24
Mine did come with the cross pin, which I believe is what your referring too. But I bought my Powertrax from a guy on TGO. So I can't be sure if he just included that with it when I made the purchase. Although I do believe it was part of the kit. As far as what it looks like, its the egg looking item in the second pic next to the torque wrench and in front of the open rear end from my previous post.
#25
Just get a used Limited slip or a Torsion carrier and some better gears. The carriers can be had for around $100 in forum for sale sections and a lot of S10s and blazers came with 3.73's stock. Just check them for RPO code GT4.
If you are going to go through the trouble of rebuilding it, do it right.
#26
#28
http://nationaldrivetrain.com/shopsi.../cases_gm.html
#29
ok i got my powertrax and i need help bad. My cell # is 9188600000
The instructions it comes with SUCK ***. I am about to freak out. I have tried every way i can think of and nothing is working.
83 7.5" 26 spline
83 7.5" 26 spline
