Overheating with my A/C on in traffic
How come my car overheats with the A/C on in traffic? On the freeway it's fine. I've got the single fan setup. Could GM be so stupid as to not know their single fan setup will cause overheating problems with the A/C on while sitting in traffic? Or is it just my car? It's ironic because you can't turn the A/C on when you need it the most (in traffic jams).
i dont see how the a/c and cooling system are related? Except for the fact that the a/c components will give off some heat but shouldnt be enough to make your engine overheat....that problem confuses me
Where do you think the condenser sits? Right in front of your radiator. If it cools air, the heat has to go somewhere. That is what the fins are for. It heats up the already hot air and passes it along to your radiator which needs cool air.
Re: Be a Man!
Originally posted by IROC-T
Not in traffic Krazzy someone will see us!lol!
