pain in my a$$ a.i.r tubes
can anyone lend a few secrets on those 2 air tubes behind the motor between the fire wall,, im fittin to just leave em there and try and ignore the eye sore they make but id love to get em out of there
I think most people put pipe plugs in them.
But yes, those AIR tubes are annoying no matter what. I adjusted the timing today and the tube that runs around the back got in the way of the wrench. Moving it out of the way requires snaking it underneath the spark plugs on the passenger side.
Then hooking up the timing light, those hot AIR tubes by the #1 plug want to sizzle my thumb.
ARGH!
ARGH!
no emmisions is not a problem im wondering how in the hell i get them out from behind the motor to clean up my engine bay idk what in the world is gonna reach up there and unbolt that clamp holding them in????
Yeah they suck. I loosened the exhaust manifolds, and just twisted and turned them till they broke. The tube running down to the cat was the worst. If you can cut the tubes at the manifolds, the little ones on each port, its supposed to be easier. A saw, or dremel to cut them off. Then you can crimp them and have them welded. Just a thought.
Its been so long since I had mine, I forgot what they even looked like.
Huh? I have no air tubes, and the engine hasnt been out. Ill agree it sucks, but the engine doesnt have to come out. I removed the manifolds, and the smog pump, and the catalytic converter, and all the lines with the engine in.
Might take a few extra tools, maybe even a few they dont make.
Edit: I just realized, he has a TPI. I have a Tbi, so It might be different. If it is, ignore my input.
