Parking Brake Cables Part #?
autozone - pioneer left CA-5572 right CA-5607
discount auto parts - wagner left F123942 right F123943
raybestos left BC93222 right BC93482
we used the raybestos brand when we converted a 1983 z28 from drum to 9 bolt disc.
that's all you'll need to switch over on the parking brake. now one thing we ran into was the hard lines on the rear itself. where the main rubber line connects there was a difference in the fitting on the hard lines that go into it. what we ended up doing was cutting off the threaded ends off the 10 bolt drum and then, using those, we cut and flared the 9 bolt hard lines with the 10 bolt threaded ends.
here's the pic and post i made over at thirdgen.org about it.
http://www.thirdgen.org/techbb2/show...ight=rear+swap
