Performer Or Torker Which Intake
#18
Re: Performer Or Torker Which Intake
Originally Posted by 85_305
Oooooh snap; what should I do about it????????
A new engine with your kind of camshaft needs to be "broken in" the VERY first time it's started. Immediately, after the break in time, change oil/filter, etc.
#20
Pre-Lubing the engine or "Priming" the oil pump is reccomended as well as filling the oil filter up with oil before starting.
A Priming rod goes into the distributor hole, you attach a drill motor that spins clockwise, the rod enguages the oil pump and as it spins it builds oil pressure and sends oil all over inside, etc. Then put the distributor back in and start your break-in.
oldschool
02-09-2016 09:21 PM
