Rear hatch problems.
Yeah, hi. I've got a few things wrong with my rear hatch. So here it is.
A) the hatch does not set even, on one side the spoiler doesnt even come close to matching up, I know it cant be perfect but it's like an inch or two off, and on the other side, it's not so bad, but it's about a half inch off.
B) The little motor thingy doesnt work right. When I close the hatch the motor continuesly makes the noise like it's trying to move but doesnt go anywhere, and it will do that until you open the trunk, so I just unpluged it.
This is really annoying. Tell me what konw.
Blue 87 IROC-Z Camaro,305 TPI
3" Flowmaster
http://hometown.aol.com/rage502/myhomepage/profile.html
3" Flowmaster
Solution for problem b: Go to your local gm parts dept. Pick up the gear that goes in the casing(attached to rear motor). Replace bad gear and reinstall...DONE!!!! I had the same problem and this fixed it right up....Over time the teeth on the gear strip out.....I think it is a total of 30 dollars for gear and new casing(just for $hit$ and giggles)
Later
1989 Formula 350
K&N air filter, air foil, TB Bypass, AFPR (set at 45 psi), A.I.R. yanked out, Accel 8mm wires, Fireball external coil, Pulley (just the crank), gutted MAF, corvette servo, Hooker super comp. shorties, 3" exhaust all the way back, No cats, Flowmaster 40 series muffler (one in one out turned down)---Developed a bad habit....bottle related!!!!75 Shot of Nitrous
http://www.theformulasource.com/owne...php?siteid=144
So they made him get rid of it...For decency ya know....But it came back the next day...
My webpage:www.cardomain.com/id/1fastformula
Later
1989 Formula 350
01-13-2015 09:52 PM
