rocker arms
Do you have centerbolt valve covers? ie, bolts running down the center of the VC holding it down or are they perimeter style? I use the crane gold rockers which are narrow and fit the centerbolt style without modifications of the VC.
I think that 1.6 and the stock cam will clear but your springs might be a little weak. I would wait till I was doing headwork and then change it all at once to 1.6 rockers. Acutaly, when I did it, I was changing heads, cam and rockers.
autoxr166
09-25-2015 04:21 PM
