Roll Cage, Did you install it?
Hi all,
I am in the process of installing an S&W 8pt cage into my '83, I am having trouble getting the metal plates hot enough to pound to match the floor? I am using a MAPP Gas torch, I was told this would work, I cant get the metal red hot however, even after like 5 minutes on holding the torch on. Am I going to have to buy an Oxy-aceteylene torch to do this? I hope not. Thanks, for the help guys.
Aaron
Aaron
I installed the SW cage about 4 years ago and used an oxy-act and it worked just fine. Make sure to anneal the welds when you are done.
Miles
www.koolmeister.com
Miles
www.koolmeister.com
Doug Harden
29
07-30-2003 07:05 AM
