Rough Idle
Rough Idle
Hi,i Have A 1992 Camaro Rs 305 Tbi The Problem Iam Having Is The Idle On It Is Surging.when I Stop At A Red Light Or Slow Down The Idle Goes So Low The Engine Turns Off,this Happens Also When I Put It In Drive . I Have No Codes Or Check Engine Light,the Timing Is Set To 0 Degrees Tdc This Is Getting Anoying Please Help
Thank You
Thank You
This is a link that has a similar issue that turned out to be the in tank fuel pump. This does seem to be a hard prob. to solve.
http://www.thirdgen.org/techboard/tb...help-idle.html
michaelzilinski
07-31-2015 08:41 AM
C4m4roJoe
07-19-2015 10:59 PM
