RPO Codes
Re: RPO Codes
not sure if they also had the rpo codes listed anywhere else but if theyre messed up youre basically sol, go to www.thirdgen.org for a vin decoder
Re: RPO Codes
Well you can soak the tape in some alcohal or just heat it up with a hair dryer and try to remove it very carfully.
http://www.fl-thirdgen.org/rpo/rpo.html
There is a link to a large list of GM RPO codes. Im sure youll find what you need there. Good luck with removing the tape. Just take is slow, those stickers are pretty tough but you dont want to take the letters and numbers off.
J.
J.
