should i have called BS on this LT1 swap?
Old 10-18-2004, 04:45 PM
  #31
Zepher's Avatar
Re: should i have called BS on this LT1 swap?
Originally Posted by chevyman502bb
Zepher, didnt u have TPI on ur T/A's LG4 tho?
ive seen LG4's run anywhere from low 15's to high 16's
anyways thanx for the replies
Ya, I did put the TPI on my LG4 and it ran a 14.1@99mph. I had put full exhaust and a cam in there as well.
The only mods my LG4 had were an Edelbrock intake, carb, and air cleaner.
Zepher is offline
Old 10-18-2004, 04:47 PM
  #32
Zepher's Avatar
Oh, and my 3rd gen has an LT1 in it,
Zepher is offline
Old 10-18-2004, 05:56 PM
  #33
92rslt1's Avatar
nice zepher!! were did you get the throttle cable from?the engine looks just like mine but i have vette covers on it. mines that red too..what headers are those?
92rslt1 is offline
Old 10-18-2004, 06:02 PM
  #34
chevyman502bb's Avatar
yeah zeph's car is badass.... didnt u do an LT4 intake and head setup as well?
chevyman502bb is offline
Old 10-18-2004, 06:11 PM
  #35
92rslt1's Avatar
to the original topic i was thinking and was wondering if he had mentioned if his lt1 combo was tuned. because some people think they can cam the hell out of stuff and not pc tune it.that robs a ton of hp.
92rslt1 is offline
Old 10-18-2004, 07:14 PM
  #36
92LT1RS's Avatar
*raises hand*
92LT1RS is offline
Old 10-18-2004, 07:26 PM
  #37
Zepher's Avatar
I did have the LT4 conversion, but I sold it a year and a half ago when I accidentally put my brothers 96 T/A into a guard rail at 70mph.
This is a more recent shot of the motor,
Throttle cable is from Lokar, headers are Heddman Longtubes.
Zepher is offline
Old 10-18-2004, 07:32 PM
  #38
92LT1RS's Avatar
nice valve cover, but where is the alternator going?
92LT1RS is offline
Old 10-18-2004, 09:10 PM
  #39
Zepher's Avatar
If I use the brackets and hub that I have then it probably won't be a problem since the bracket will sit .5" from the block and head with small spacers.
I may get an alternator relocation kit to mount it lower since that may be the only accessory that I will run, still debating on power or manual steering.
here is what the spacers look like,
Zepher is offline
Old 10-18-2004, 09:39 PM
  #40
85_305's Avatar
I figured that aluminum engines were beasts.. why else would the new BEASTLY Camaro/Trans Am's use them? Reason I was asking was cuz my g/f's stupid ricer-bro doesn't ever get on his moms truck "because it has an aluminum engine, and i dont want to warp it/over heat it".. I thought to myself; ya, the new Camaro's have all aluminum shiz and they never overheat.. why the fock would your truck overheat? lol
85_305 is offline
Old 10-18-2004, 10:01 PM
  #41
Lungz's Avatar
It's more of a what If i think. Yes, they are harder to overheat, but once you overheat an aluminum head its usually shot, whereas a steel/iron head can last through an overheat or two or more before warping.
Lungz is offline
Old 10-18-2004, 11:35 PM
  #42
92LT1RS's Avatar
Interesting. what was the reason for using the spacers and what did you do for the hub? I would assume you just spaced the actual balancer off the hub itself?
92LT1RS is offline
Old 10-19-2004, 11:56 AM
  #43
Zepher's Avatar
I am using a B-Body hub with an F-body accessory bracket.
Last time when I put the accessories on, I had my b-body bracket at a friends house getting powder coated and I used the f-body bracket and the belt wouldn't align to the hub so I grabbed those spacers (don't know where they came from) and put them between the bracket and block and the belt lined up.
Oh, and about the aluminum LS1 motor, people that want tons of power from them usually go with the Iron 6.0 Liter truck motor.
Zepher is offline
Old 10-19-2004, 02:27 PM
  #44
92LT1RS's Avatar
Oh ok. I wasn't aware there was a difference between the accessory brackets and hubs
92LT1RS is offline
Old 10-19-2004, 03:34 PM
  #45
91RSLT1's Avatar
Where did you get the valve covers that say chevorlet? I really like those and am currently looking for a set. Any links?
91RSLT1 is offline
Quick Reply: should i have called BS on this LT1 swap?
