should i have called BS on this LT1 swap?
Old 10-19-2004, 05:15 PM
  #46
klumb15's Avatar
Re: should i have called BS on this LT1 swap?
can you put a 6.0 truck motor in a third gen easily??
klumb15 is offline
Old 10-19-2004, 08:25 PM
  #47
85_305's Avatar
Umm.. I have been hearing more of it lately. Can it be done; yes. Is it easy; I dunno. But if ya could.. sweet Jesus do you have yourself a car
85_305 is offline
Old 10-19-2004, 08:45 PM
  #48
klumb15's Avatar
i checked it out, it says its 300 horses, i didn't find the ft/lbs but i imagine that is why its getting a bit more popular....i first thought a LS1 soudns like a better choice, but if the 6.0 is creatin some amazing foot lbs of torque, that would make a really fun car!!!
klumb15 is offline
Old 10-19-2004, 09:58 PM
  #49
92rslt1's Avatar
6.0....its not exactly a performace motor stock its a truck motor. for the horsepower you want and the weight differences you will be saving and you might as well get an ls1. you would basicaly be doing the same swap anyway for less stock horsepower and more weight. normaly the iron 6.0 is used for monstous horsepower for drags and stuff not saying others dont have it but i think a ls1 is the best choice for the already heavy 3rd gen car.if you got a 6.0 you would pay way more for the swap than the 300hp is even worth.you can get 300hp out of a standard 350 cheaper and with the same weight.
92rslt1 is offline
Old 10-19-2004, 10:12 PM
  #50
92LT1RS's Avatar
I'd have to totally disagree. do the LQ9, put in a good performance cam, put a set of ported 5.3L heads on it, leave the stock truck intake (makes more torque), and get some good headers on there and you're going to make some good power. The weight difference is no different than a SBC, maybe a few pounds more, but its not going to make it a whale like you're talking about. The advantage to the 6.0 is that you can bore it far more than you can the LS1 and you don't have to resleeve it to make more cubic inches. If you plan on making serious power down the road, do the 6.0. If you just want a newer engine with more power than you've got right now, lighten the car a little, and have no plans for power down the road, do the LS1. Its going to be the same amount of work either way.
92LT1RS is offline
Old 10-19-2004, 11:01 PM
  #51
92rslt1's Avatar
i agree with that.... but its almost identical to the ls1 swap and you are gonna need to do all that when you could just put in a ls1 which is lighter and is gonna respond better to the same mentioned mods.
i agree. i should have been more clear. i was reffering to the ls vrs iron 6.0 weight. i was using the standard 5.7 as an example meaning for the money invested in the swap alone you could save money by simply giving a standard 350 300hp.
i agree. the 6.0 will make alot of power if you have the funds,but so wont the ls1.
cant realy agree with that.the ls1 is a power plant stock.heck i saw a single turbo ls on ebay a few months ago putting down 1200hp and running in 9s.im sure it was rare but im just saying that theres lsx motors that run tens everyday and on the strip a few hunded pounds might make the difference between winning and losing.
92rslt1 is offline
Old 10-19-2004, 11:41 PM
  #52
Zepher's Avatar
Originally Posted by 91RSLT1
Where did you get the valve covers that say chevorlet? I really like those and am currently looking for a set. Any links?
They are made by Proform and sell on Jegs for about $130..
http://www.jegs.com/cgi-bin/ncommerc...64&prmenbr=361
Zepher is offline
Old 10-20-2004, 12:02 AM
  #53
96formulaLT1's Avatar
the 6.0L LQ9 iron block rocks, you can put a 4" stroke crank without having to clearance the bottom of the cylinders, 5.3L heads for higher compression, and an LSX intake on top for a ton of power. the 6L LS2 blocks are aluminum and the cylinder skirts drop down farther so you have to clearance them for the high stroke crank.
and the LT1's can use the same rod/pistons as a gen1 SBC. the only thing different is the 1piece rear main seal and the reverse flow coolant wich requires a different block and heads. and the cam driven water pump and the optispark.
96formulaLT1 is offline
Old 10-20-2004, 12:21 AM
  #54
92rslt1's Avatar
yup,but just to clarify they stock to stock are different. the lt1 rods and pistons are stronger and use a metric chromoly ring set. however they are interchangable with say a l98's piston and rods thus i believe is what was meant by 'they can use the same'.
92rslt1 is offline
rocketman051894
01-30-2015 03:23 PM
InfernalVortex
01-17-2015 09:35 AM
cmdeshon
01-04-2015 11:15 AM
Ricardo
11-29-2014 10:58 AM
Nostang 96z
09-14-2002 08:22 PM
Quick Reply: should i have called BS on this LT1 swap?
