speed limiter?
Originally posted by mikey dragster
MY 91 TBI CUT'S OUT AT 117MPH AT 4,400RPM'S IN OD
OR AT 117MPH AT 6213RPM'S IN DRIVE.
BUT UNDER MY TBI I GOT A 350. OR RATHER HAD A 350 NOW ITS GOINT TO BE A 406.
Originally posted by Fast_B4C
I dont have a speed limiter and it says RS on my car??????
It's probably 117 on both Chevy and Pontiac. Speedos aren't that accurate at high speeds anyways.
Originally posted by Rippin92RS
Yup, 115 here check this out:
http://www.thirdgen.org/newdesign/tech/unlimited.shtml
-Rippin
-Rippin
Originally posted by 92BLKL98
I am a big fan of thirdgen.org but to me the guy who wrote this as well as thirdgen.org dropped the ball on this one. Wouldn't it be a cleaner job to just remove the speed limiter in the memcal. If you have a buddy with a prom burner and the software it is very simple to do. The limit set at the factory on the cars with Z rated tires at an unobtainable 255 mph.
-Rippin
It's easy to reprogram the TBI cars since the chip isn't in a large holder like the TPI cars and the later V6's.
I reprogrammed my friends 91 TBI Bird when he went from 2.73 gears to 3.42. He'd hit the limiter at 92mph since the ecm was still reading 115-117 due to the gears.
