Squeek from clutch fork pivot point
I have a 1991 Camaro. At the pivot point for the clutch fork, there is a squeek sound. It goes away if I put slight pressure on the pedal. I put some grease on the pivot ball and it worked for a little while, but a little later it wore away and the noise came back. Do you have any ideas how to permanently stop the squeeking.
is it the throw out bearing that might be causing the real problem or are you for sure its the pivot ball? i dont know all that much but if applying just a little pressure stops the noise it might have more to do with the throwout bearing. just something else to look into.
Nick J
Nick J
I know it is not he the thow out bearing, Last summer a guy told me it might be that. So I took everything apart, and re-greased it. Put it all back together and it still made the noise. Than somebody said to check the pivot point. There is a small "ball" that the fork pivots on. And the fork vibrates causing the squeeking. I lifted the fork off the ball and put some grease between them. And the squeek stop right away. But after a little while the grease wore away and the squeek started again.
When I get home, I'm going to take a very small about of foam (very small) and put it between the fork and the ball. That way there isnt direct metal to metal contact. I dont know how long that will last though.
Originally posted by Z28SORR
What sharp little ears you have.
A heavy grease like axle or bearing grease should last a long time, unless your getting water in there thats washing it away.
Ya, I can hear it really good. And I've been trying to fix it for a while now. My dad thinks I'm crazy, spending all my time tring to fix a squeek. But to me it's all I hear.
