Starter issues...please help!
Hi guys, I am having a big problem finding a starter for my 83 Z. I was running the stock 305 with the Borg and Warner 5 speed manual. I just dropped a rebuilt 350 into it, and the starter that I had just didn't want to turn it over fast enough. I figured no problem, however I have tried starters from 3 different auto parts stores, and have called 7, and 2 shops. The bendex on the starter is running into the flywheel. I have tried shims, however I have it down to 5/16 on an inch still with no luck! If I leave the starter loose in the bolts, I don't have any issues, it starts everytime. I am worried about shimming it out more than I have tried already. Does anyone know about a different starter, maybe for a newer or older car? All of the parts stores only list one starter for an 83 regardless of the tranny type. 84's list 2 different starters, however they are special order and I can't return it if it is wrong. If anyone could help it would be greatly appreciated, I have to break this motor in!!!
i bet you used a different flywheel on the 350 than the 305 had, i believe the 305 uses the small flywheel, and the 350 may use the large one thus causing your problem
Pics of the Firebird
84' Firebird, 305ci lg4, 700R4, 288/292 duration .450/.460 lift,Edelbrock Performer intake, Holley 600cfm 4 barrel, K&N filter, Pacesetter Headers, 3'single exhuast, dual out muffler, no cat,Motive 3.73's and Auburn Posi
1/4mile 15.17sec @ 92.5mph
84 firebird, motorless and trannyless at the moment (was 4cyl 5spd)
parts car/race car, (at least it will be eventually)
Try shimming just the inboard bolt closet to the flywheel. Use a standard washer that will fit over the bolt between the starter and the block. Usually one washer creates the clearance needed although in some cases two washers may be necessary.
jackpawt883
09-10-2015 08:53 PM
