which starter for new motor
I am using a 14" 2 piece seal flexplate, 168 tooth i believe.
wil my stock starter off my 305 work or do i need a new one? will a regular starter work or must i use a ministarter....im using shorty headers....
If you are using a 168 tooth flex plate the original 305 starter will not work. Stock was 153 tooth. Starter bolt holes will not allow starter gear to be aligned in the correct postion. I went with a 168 tooth on my 89(383) buildup and got a Summit "Protorque" mini starter. Adjustable for 153 or 168 tooth, reasonable price at $147.
I've never heard of ANYBODY running one, but I don't think I ever specifically read that it doesn't work. I just think that if it did, somebody would be using it and I'd know about it. You may want to do a search on thirdgen.org.
