Starter won't turn, battery has power
Old 02-02-2011 | 01:45 PM
ljmerrill010's Avatar
Red face Starter won't turn, battery has power
I have a 84 Z28 that won't start. It was a gradual problem, not happening all at once.
The first occurance happened when I tried to turn my key and instead of turning over, the starter made a clicking/hum noise. I cursed, flicked my lights to see if I had power, and I did. Tried starting it again, and it started right up (not right up, I have a fuel regulator problem I think, have to sit on the gas a little bit till it's warm).
Over the span of 3 days, the noise would happen more often than my car would start, and now it will not start altogether. The starter is only two months old along with the battery, and an alternator was purchased and put in yesterday.
I haven't been able to put my car up on my ramps to see if the connections are good, but somehow I don't think that's it anyway. What can I do? I'm a fix-it-myself kid, so I don't want to hear, "it may be (this), you should send it into a shop to check it out."
Old 02-02-2011 | 02:21 PM
Marc 85Z28's Avatar
Re: Starter won't turn, battery has power
Just because some electrical items operate does not mean that the battery is charged enough to start the engine. PROPERLY test the battery first.
Old 02-02-2011 | 02:22 PM
I've gotten a jump to test that since I don't have the electrical equipment to test currents. Same problem.
It was being jumped by a weak, 4 cyl Focus, would that matter?
And my car was starting for a few days, so my battery had to be okay. I thought it was my alternator, but I got a new one, tried to get a jump, and nothing.
Old 02-02-2011 | 04:38 PM
BigBadLou's Avatar
Welcome to the board, ljmerrill010! A DIY kid? Smart choice. You've come to the right place.
If the click you're hearing is a loud one, more of a clunk from the starter, it is commonly a problem of the bendix hitting the flywheel/flexplate and not engaging the gears.
1) One possible cause would be improper shimming of the new starter. But in that case, you would have seen this happen shortly after installing the new starter.
2) Another possible cause is electrical. If the starter solenoid is not getting full power from the key ignition circuit (bad connections in one of more of the several components in the path of the current), it can only extend the bendix to hit the teeth of the flywheel but won't have enough power to engage the teeth (at which point, at full travel, the starter motor engages and turns the engine over). You can easily check for this by putting the car on ramps, setting the parking brake, making sure the transmission is not in gear and from underneath the car, using a big metal tool (screwdriver) to touch the small starting post to the big positive post on the solenoid. That will bypass the starting circuit and will provide full power to the solenoid. If that works, you have a weak component (bad connection) in the starting circuit. That could be in the ignition cylinder, in the Starter Enable Relay, the shifter Park/Neutral switch or any alarm relay or other aftermarket installation. The fix for this is very simple: either find and replace the weak component or install a Ford starter solenoid. Yes, you need Ford parts to make a Chevy run, ironic, huh?
Anyway, let us know what you find and once we know what it is, we can walk you through the fix easily.
Lou
Old 02-03-2011 | 09:38 AM
Marc 85Z28's Avatar
I'm betting on a battery, battery connection, or battery cable issue. Check for tight, corrosion free connection at both battery terminals. It probably would be a good idea to remove the battery and have it tested - most major parts stores have the equipment to do this. If it checks OK, thoroughly inspect the battery cables, the positive (red) cable in particular. Corrosion can get inside the cable's insulation and cause excessive resistance.
Jump starting sidepost batteries without losing current through poor connections is not as easy as most would think.
Old 02-03-2011 | 10:04 AM
Z28SORR's Avatar
^^^ ditto!
DirtyDaveW
12-01-2016 05:37 PM
eazyZ
03-01-2015 07:12 AM
Oncomingstorm22
01-22-2015 07:15 PM
97z28k&N
01-09-2015 04:58 AM
XtremeLt1
09-13-2002 08:50 PM
Quick Reply: Starter won't turn, battery has power
