Stock L98 numbers
#31
My car ran 14.3 with 60K miles on the motor, 120K on the car, rebuilt tranny, and 2.77 stock gears. Nothing, even paper filters, the car was totally stock. Pinging and not tuned at all. I must admit, I was surprised
Will
Will
#32
Originally posted by dj haf
u'd be lucky to run those numbers though... our cars don't run exactly the same as they did from factory if they were still stock... a little wear and tear will knock it down a few tenths within 10 to almost 20 years, wouldn't you think? i took my car down to moroso, 1990 iroc-z, fully loaded 350, G92, 3.23 gears... the works, weighing in at 3600 lbs with me in the car and not much gas. what did it run? 15.2 to 14.9... but then, by luck, i cagged a 14.8, and all it had was free ram air and flows. without it i probably ran low to maybe even mid 15's. reason being my cats were clogged and probably so are my fuel injectors. car only had 95,000 miles on it. then i ran a 14.5 with all the crap in my sigs and crappy tires. not to mention that along with our engines being 10-20 years old, so are our tranny's... even when rebuilt, they still aren't the same. i wish i was running low 14's stock though... i guess ill gain the power i used to have when i get new fuel injectors and rebuild my L98... waiting for the flow to put in a 383 or 396 stoker kit on it, though. any way you put it, if you go out and buy yourself a iroc-z/z28, and you run in the 14's, you should be DAMN happy you've gotten that far with a car that's aged. if i were back in 1990 and i bought my car back then, im sure she'd be running low 14's, but since im not, and the owener who had the car before me didnt take care of her, i've gotta do with whatever she's got in her.. which still isnt what she had before when she came from the show room. u'd probably be really disapointed if you bought a stock iroc-z/z28 and thought it would run low 14's... not when your car has aged
Thats the thing, if the car has been taken care of then it wont fall off...take my ride for example (G92 LB9)...when i bough it it had 56,000 on it..i bought it fomr my uncle who drove it from MI to CA many times..(all except 7-10,000 miles)...when i got it i put another 20,000 hiway miles before i took it to the track...the only modes the card had was a K&N and a ram clutch..trapped 94 first time out...honed my launching skills and was cutting hi 1.9's on a good set of street tires (not DR's)...bought a flowmaster and ground down the EGR walls and it trapped almost 97...
best the car ran was a 14.12@96.87....91 porker, i mean GTA LB9 5 speed 3.42 gears...(1 of 164 G92 5speeds in 91)....i never weighed the car. but its a full optioned t-top car...id slightly pull LT1's to about 70, then id loose probly 2-3 tenths after half track
if the car has been beaten, i mean like more time on the floor then not then its not gonna run fast..but if its taken care of (hiway crusiing) then itll run as fast as it would off the showroom floor
#36
Idle, Mileage, Throttle Response, you name it. My car was idling very inconsistently months back. I had done a full tune-up after I bought the car and changed various ignition parts and so on, but never messed with the TPS or IAC. I calibrated the TPS just about a month ago or so and immediately could feel the car pull harder, much less hesistation, still pinged, but thats due to the ****ty fuel in cali and some other issues. But what a difference. Nice smooth idle.
If anyone has ever had the throttle body off the car or turned those torx bolts even a c-hair, it will go out of adjustment. Mine was way off. Do a search on thirdgen.org, and you will find all you need to know about this adjustment. Take your time, as you don't wanna do it 4 times like I did.
Will
Will
