Stock shift points on a 700r4
Originally posted by z2894convertible
Are you saying 1st is 4500 and 2nd and 3rd is 5600?
To change this you must replace the governor in the transmission.
I control my shift points with that TV Cable adjustment.
Mine is shifting at 5K in all gears at WOT, but I don't have any power from 4600-5000, it just revs up and doesn't go any faster.
Btw, I hate Auto's so as soon as I can afford it, both of my cars are getting manuals.
Originally posted by thezisking
Mine shifts at 6500 into 2nd, and right around 6000 into 3rd. It's completely stock. 86 Z-28 with 305 TPI
TPI has a very hard time above 5K rpm.
I believe mine shifts at 4600 from 1 st to 2nd and 5600 through the rest of the gears. I am not real sure on the rpm from 1st to 2nd because it goes through 1st real fast. I wish mt tranny switched at 6000. Looks like I will be getting a shift light so I can shift myself when I am at the track.
My car doesn't red line until 6000. And also I take that back. It shifts at 6000 into 2nd and about 5500 or so into 3rd. I don't think my tach is off because I hooked an aftermarket tach up to check and they were almost dead even.
You can change the WOT shift points by working with the governor. If the transmission shifts at a point higher than you like when in the "D" position, you can not shift any earlier manually. You have to bring the WOT shift points down with the governor.
