Stranded for a few minutes.
Guest
Posts: n/a
I shut the car off, went inside for 5 mins, came back out, and car wouldnt start. Locked/unlocked (keyless entry/alarm which I DID NOT INSTALL, and will be taken out soon), opened/closed doors, checked battery cables, nothing. Turned the key, security light and all the other crap comes on, but it doesnt even turn over.
I wait about 20 mins, come back out, and it starts up like a champ. Am I missing something?
Guest
Posts: n/a
Originally posted by RSsleepr
Check out this thread:
http://web.camaross.com/forums/showt...hreadid=229939
Guest
Posts: n/a
Thanks for the help.
Should also mention that the guy before me installed some crappy alarm, which would go off all the time, so I ripped out the speaker under the hood.
Sometimes, even when the alarm is disabled, I can just tap underneath the dash (where the whole mess of alarm crap is) and the alarm will go off. Its a huge mess under there. Ill take a pic.
Guest
Posts: n/a
Originally posted by aklim
You sure it is not the alarm system acting up? I would disconnect that now and see what happens.
I am probably going to pay a stereo shop to have them remove it and have a factory chevrolet keyless entry installed (the 96 and newer styles). I put this on my truck and very happy with it.
I had this happen to me once also. The Great J is right, it was the VATS acting up. You have to sit and wait for 20 minutes or so for the security feature in the ECM to allow you to try to restart. It only happened to me once, but it was damned annoying.
