stupidest problem around
heres the deal my cooling system is working well the only thing is my fan relay keeps screwing up as to the point where if my temperature gets higher then normal my fans arent working and i have to go wiggle the relay around till they start. then its fine
every once in a while they get lose twice in 2 days and thats the nmost
what can i do
what can i do
IF the relay is OK and the plug just keeps working its way out just put a wire tie around the relay and wires and pull it tight .. if the relay is bad just go and get one from a salvage yard or buy a new one . also check inside of the plug and see if there is any corrosion in the terminals if so clean it out with some thing like a small pic or screwdriver ...
i went with a v-6 single fan! got it cheap at the junk yard. i wired it constent and it keeps the engine real cool. other option, drain all antifreeze and put in distilled water with water water. when winter come, either park it, or reinstall coolant.
i disconnected it and reconnected it i looked at the connections there not corroded but they have like this grey grease proabably dielectric grese which is good but the fan kicked on all day yesterday as normal some maybe its ok
