Which of these is the best way to go for cat's?
http://www.jegs.com/cgi-bin/ncommerc...92&prmenbr=361
Should I get the one made for the 5.0 f-body, or should I just get the basic
2.5'' In/Out, 13.25'' Long for $54?
My exhaust is 3", will having the cat 2.5" in/out really kink me up, or will it be un-noticeable?
Thanx all,
Matt
Thanx all,
Matt
Re: Which of these is the best way to go for cat's?
Do what I did. I found a county that dose not do emissions testing and take out the cat. You will gain about 20 to 25% more horse power. If you can't, go with one that is 3" in/out otherwise it will not flow out the way it should.
Originally Posted by CamaroJosh
There is no way i can gain 40-50 horsepower just by removing my cat....
I thought it was only 10 mabye 15 hp
Good luck.
Well it's not so much the emmsions testing I'm worried about; it the fact that the local exhaust shops cant LEGALLY weld up anything exhaust-wise if yoru car is supposed to have a cat, but doesn't.
BUT.. since my exhaust is 3", going w/ a 2.5" cat would be a bad idea?
EDIT: But by what V8 Rumble is saying, it wont much matter if the cat is 2.5" or 3", right?
Whoa, whoa... I hope I didn't come across as saying that! When I replaced the cat on my truck, I went from a 2.5" inlet/outlet to (you guessed it) a 2.5" inlet/outlet...
Flow through an exhaust (or intake) system is going to be limited by whatever the most-restrictive item is - in other words, if you've got a 3" exhaust, but a 2" muffler, you won't be able to flow any more than what the 2" muffler allows.
Now that would normally lead you to think "Well I'll just get a 4" exhaust system, & that'll solve all my problems!" Makes sense, except that a certain amount of backpressure in the exhaust is actually a good thing, it helps to scavenge the cylinders (which allows more fresh air/fuel to get in), so going with a "too big" exhaust can be harmful as well.
As you can probably tell by now, there's a fair bit of science involved with this - much more than would fit in a message board post like this. Best "concise" advice I can give you is "If in doubt - or if you're not regularly winding your engine to 6500 or more - you're probably just fine with a 1-5/8" header, with the rest of the exhaust being 3" (if single) or 2-1/4" to 2.5" (if dual)." (Note: I've read somewhere that a properly-sized single exhaust is actually a bit more efficient than a properly-sized dual exhaust, because of frictional losses along the wall of the pipe - I don't know, & I suspect that the difference is probably marginal.)
I've also seen information to the effect that there's a LOT of power to be found in the right header collector - meaning 15 to 20 horsepower with that change alone! Needless to say, I'm trying to get more (definitive) data on that...
I guess what I'm trying to say is "Don't cause an artificial restriction in your exhaust, but don't go nuts hogging it out either." (Sorry I can't give you a specific, detailed answer, but it really depends on the car...)
Matt, grab a Carsound or Catco 3" in/out on eBay for $40-$50. Some people say that the Catco's don't last, but mine came with a 5 year warranty as long as it was installed by a shop.
- Justin
- Justin
Well, thanks for the help v8-rumble and Justin I will look up the 3" cat on ebay.
EDIT: Justin, I just found a 3" Catco for like.. 48 dollars WITH shipping. Plus, that is a damned nice looking cat
Is carsound and catco any good though (over a stock convertor..)?
Do these prices/auctions happen often w/ these low prices?
Forget about E-bay and just order a direct fit Catco Cat from Summit Performance for your model car and motor. This will ease any installation problems with a one size fits all.
Wow.. that's a nice and cheap way to go (BTW.. it's like 130$ for a 3" catco off of summitracing.. whereas on ebay it is 45 bucks or so w/ shipping )
But I am having an exhaust shop do it for me; they can dick around w/ making the ebay universal catco fit, lol.
Matt,
Are you using the factory y-pipe on your car? If so, I was wondering if you new what it's outlet diameter was. I had posted another thread regarding y-pipe size, but no one really replied. I also want to replace my cat, but would like to mate it to a new 3" flomaster cat-back setup.
But now I just need to figure out what the cat inlet (y-pipe outlet) diameter needs to be so that I can buy the right cat before ripping out the old cat.
Thx
Jeff
'91 Z28 305 TPI, AC Delco Rapidfire2 Plugs, Smog pump removed, TB Airfoil, new paint job, and many more projects planned...
Thx
Jeff
No, I am not using hte factory y-pipe. The factory y-pipe on our 305 cars are HORRIBLY designed, and will rob power like ****'s. I will be using a hedman y-pipe
Honestly, I dunno what the outlet size on the y-pipe is. But usually you have to buy a y-pipe designed for your exact headers.
09-11-2015 09:44 AM
