Thinking about 89 IROC-Z, have questions
#16
Dancing around, that's kind of weird. You wouldn't think that would happen just from high mileage. Did it look like the valve cover had been off before?
Anyway just tighten it down about a quarter turn at a time while it is running till it stops clicking then thighten another 1/4 to 1/2 turn. If that nut is really easy to tighten then maybe that is why it came loose. Might need a new nut.
The roller rockers would help mostly because they are much more consistent than the factory ones but probably not enough to really notice. Since the stock heads are not really made to flow dramatically better at higher lifts and increasing ratio may involve machine work on the pushrod guide holes it might not be worth it to go to 1.6 ratio rockers.
Congrats on the purchase, I love that feeling of driving home a newly bought car.
#18
Originally posted by TheGreatJ
If its just the one rocker thats loose, and its REALLY loose, you might have a collapsed lifter. That'll cause the noise too cuz that valve won't be opening AT ALL. Good excuse for a cam swap.
#19
Sounds good,
I have a 305 from a 85 or 86 camaro, will the pushrods interchange? I hope it is not a collapsed lifter, not a real big prob, just more hassle. Yes, it did look like the valve cover has been off. There was an orange rubber gasket, and it was blown totally out right near that rocker arm.....hmmmm. Will a visual inspection be close enough to compare the pushrods? I would think so. Let me know before I go putting it back together. Also, I know this is primitive, but I tried pusing down on the pushrod onto the lifter, and it felt stiff, not weak. I dont think this matters, but thought I would throw it in. Thanks
BamaZ28
BamaZ28
ChrisFrez
01-18-2015 08:05 AM
ChrisFrez
01-11-2015 03:47 PM
