Throttle bodies pouring fuel at startup.
Hello,
My car is now dumping fuel in at an overkill rate, causing the plugs to foul out quickly... Thus the car turns over, yet will not fire. Where are all of the regulator switches etc that would control the rate of fuel being pump in at 0 throttle position during the start up? ECM problem? Ignition module failing? Throttle position switch not functioning? PLEASE HELP...
Scott.
Scott.
stockssn2o
05-25-2015 08:54 AM
07-04-2005 05:00 PM
