TPI block w/ 400sbc heads would LT1 intake work
I'm trying to convince my friend to change his TPI intake to an LT1 intake but he told me that he has chevy 400 sb heads. Now would the LT1 intake still work? Would he have to open upthe intake ports alittle?
Other than the regular modifications needed to retrofit the LT1 intake to a SBC, nothing else AFAIK. Check out www.LT1Intake.com for the needed changes.
-Corey
NOTE: Wait, not sure but 400 heads have something weird with the coolant passages don't they?
-Corey
Originally posted by 1BadBrd
coolant doesn't pass through the intake so i didn't think i would matter.
John@LT1Intake.com
Yeah, I had a 406 I was building for a freind about a year ago. Had to have a shop drill the Dart heads so they would work. I didn't trust myself enough to drill on a set of two thousand dollar heads.
there must be something i don't know about these heads then. Steam??? HMMMM i will have to ask then.
I know about the moding for t stat and distributor and bolts and fuel lines but as far as the normal mods i didn't know if it had to any major moding to make it work.
