tpi mystery canted valve heads?
Old 02-13-2012 | 01:59 PM
  #31
clemente's Avatar
Re: tpi mystery canted valve heads?
im even starting to think it might be cheaper if i buy a totalled out ls1 camaro and convert it over. it wouldnt hurt to much to start over since that is how i got this motor that i have now. i only ended up paying $35.00 for motor, trans, disc rear end, and wiring after all was said and done. plus i might enjoy parting another camaro out.
Old 02-13-2012 | 05:00 PM
  #32
clemente's Avatar
plus i dont know why anyone would buy a different intake when the bolt holes line up perfecly and the only difference is the angle. all anyone would have to do is bend a few bolts with no head at the right angle and they will hold down the intake like they were meant to.
Old 02-13-2012 | 07:35 PM
  #33
Marc 85Z28's Avatar
It's more than just the bolt angles. The bolt locations are different, and most importantly, the port size/shape/location are different too. You cannot get around it, you MUST have a Vortec specific intake!
As for the rockers, you need self-aligning rockers. You can use regular rockers, but you will need to pull the pressed in rocker studs and machine the heads to accept screw in studs and guideplates.
Old 02-14-2012 | 12:22 AM
  #34
clemente's Avatar
lol ok! i think the best thing i can do is just put the tpi back together with some new aluminum heads and a tpi intake from FIRST. that thing is so massive that i dont think i'll have too much of an issue at high rpm like the origional restrictive tpi manifold. i'll have to get some literature on how to check engine specs and find out what is beneath the heads that are already on it. on the upside i should be able to get some cash for the intake and heads that i currently have.
10-31-2016 11:09 AM
oldschool
02-09-2016 09:21 PM
Roadie
02-16-2015 10:34 AM
BIGCOWL-IMP
12-19-2014 06:59 AM
Makaveli
07-24-2002 11:27 PM
Quick Reply: tpi mystery canted valve heads?
