transmission coolers
a cooler with at least 16,000 gvw rating. Try to run the largest tranny cooler you can. For every 20* cooler you keep your transmission, you double its life. The hottest you want the trans fluid to get is 170* F. At this temp, the fluid can last 100,000 miles, any hotter and its life is significantly shorter.
what about over cooling. ive seen someone put a one way valve thermostat on it to keep the temp from dropping too low.
http://67.104.247.214/jmb/firebird/home.htm
click mods and look down at july 2003
